TwinTurbo.NET: Nissan 300ZX forum - Timing is on 15 btdc, plugs are gapped correctly,
Worm Boy
on January 19, 2007 at 9:00 PM
hard starting when cold
posted by wilkendw
on January 19, 2007 at 08:42 PM
no boost leaks, and O2 diagnostic came out good. I will check the tps. The TPS can be checked through the safcii, right? But I'll follow the manual to be safe.
What does cold weather have to do with my
Worm Boy
19:26:17 01/19/07
How bout Fuel Pressure Regulator or Fuel Damper? (n/m)
TTFairladyZ
19:32:57 01/19/07
I forgot to add that to the list. Did all fuel related
Worm Boy
19:34:50 01/19/07
wilkendw
20:42:05 01/19/07
Timing is on 15 btdc, plugs are gapped correctly, -
Worm Boy
21:00:38 01/19/07
The O2 sensors only affect the car while it's
Worm Boy
22:08:43 01/19/07
Re: The O2 sensors only affect the car while it's
wilkendw
09:52:58 01/20/07
What AFR issues could be associated? I'm thinking
Worm Boy
16:51:41 01/20/07
Re: What AFR issues could be associated? I'm thinking
wilkendw
01:06:17 01/21/07
I ended up putting starting fluid in the intake and it
Worm Boy
15:35:15 01/21/07
I tried turning my car on this morning around 4a.m. before
Worm Boy
15:46:06 01/21/07
Did you check ignitor module ? (n/m)
njz
21:45:55 01/19/07
You mean PTU? IF so, I did replace it along with
Worm Boy
21:53:35 01/19/07
How cold are you talking?
SactoTodd
10:14:01 01/20/07
Oh not that cold. The coldest it gets over here in
Worm Boy
16:34:57 01/20/07
Did you have it load tested? (n/m)
SactoTodd
17:51:09 01/20/07
Yes, I took it to AutoZone. (n/m)
Worm Boy
18:26:59 01/20/07
Re: Yes, I took it to AutoZone.
merlin3
18:29:13 01/21/07
Re: What does cold weather have to do with my
canyoncarver
18:35:53 01/21/07
I'll have to check the belt then. Are you familiar
Worm Boy
19:15:13 01/21/07
Remove the SAFC first. (n/m)
canyoncarver
08:31:54 01/22/07
